Boost problems. Car will only boost to 12psi even with the hose to the boost solenoid disconnected.
Checked the compressor wheel and it is not hitting and has no play.
I have not checked the IC yet.
Built car to 5psi and son-in-law stood to the side with hood open and could hear no air escaping sounds.
No exhaust leak sounds. I do not run a cat.
Car runs good, no misses.
My problem started out going to 19psi and then boost would go to 0. I replaced a suspect hose and now only get the 12psi.
I assume this is mechanical since I only got 12psi with the boost solenoid hose disconnected?
Could this be an exhaust wheel problem? Sticking puck? or do y'all thing it is a IC leak that will only let me get to 12psi?
TIA
TIA
