quickbrick
- Oct 13, 2001
ok, with my stock turbo using the thrasher chip my car would boost up to 19 psi then fall to 17psi, which i really liked. from what i heard its supposed to spike like that with that chip. even though thrasher says nothing about a quick spool on it. but my problem is since i put the new turbo on, it boosts up to 19psi for a couple seconds then falls to 14psi(seems real slow) for a few seconds then it raises to 16 psi and runs good the rest of the way. what could be causing this drop in boost? everytime ive raced my car lately i take off the line hard but i get passed in the mid range then i cant catch up. any good ways to check for leaks on the turbo. for some reason i keep thinking its leaking. any ideas? i have the wastegate rod at about 4 3/4" length, i think stock is 5 1/16" if that helps at all.thanks
