Turbolink has a cable/sensor that feeds a boost reference voltage into the MAT sensor input. So while the ouput would be in degrees, you can see about what the boost is doing.
A few runs watching the boost guage will tell you what the ref in degrees to boost is, then you can look at your data logging to figure out where your at, and see what the boost is doing
