quote:
Originally posted by JayC
The harness will work without turbolink. All you need to do to use the variable timing stuff is have the harness plugged in, you don't need TL.
Jay, Ken or someone,
Ive been reading all the threads that talk about this stuff but Im still confused. Maybe someone could answer the basic stuff that Im missing. Cant understand the details if you dont get the basics, so....
1. What does the boost sensing harness and 3 bar sensor do? Does it provide more feedback to the ecm? Where is the information being routed to that the sensor picks up?
2. Using this information you can use a variable timing chip. If its not giving away any trade secrets, where does this information go in the chip and does it use the feedback from the maf sensor to adjust or do you just use the info you get from the sensor to burn a variable timing chip?
Maybe someone could write up a whitepaper on this stuff. Im sure Im not the only (or first) one to ask these questions.
David
David
