Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
Was thinking
; Are there diminishing returns in mass flow as temp increases and at what PR/temp does this occur?
Goal:
Create graphical display of calculated mass flow vs charge temp at different PR with/without alcohol.
Disclaimer:
These are calculated numbers and may not correspond to your set-up.
Assumptions made:
Static: 231 CID @ 90% VE / Turbo Efficiency 65% / Baro 14.7 / RPM 5000 / 70F Ambient / No IC /
Definitions:
Boost (PSI) = At Compressor outlet
Temp (F) = Compressor outlet temp
Temp Alky (F) = Charge temp with alky injection based
Mass Flow = lbs /min
Goal:
Disclaimer:
Assumptions made:
Definitions:
