Junk. Get the Rinaii tankless heater, they put out more hot water and have flow controls that will not let your water get cold if you draw too much, it limits the flow. We see about 6.3GPM at a 55 degree rise, which is PLENTY of flow for 3 showers at the same time with flow restrictors installed.
The Rinaii 2532 has the ability to link up with up to 5 units and they work in parallel and can produce up to 20 GPM of hot water with a 55 temp rise. Make sure you do the proper research on GPM flow rates and the amount of flow neccesary to start the unit. The Rinaii has the industry right now with only .5 GPM. That is a lot more than you think and untill you hit that mark it will not fire. The Bosch only does .7 if I am not mistaking. Also, the Rinaii has sealed combustion drawing its air from outside. Check out the Web site.
My cost on the unit is about $1100 including 1 BC controller and typical venting required to complete installation. You will also need 189,000 BTU's available at your point of distribution for gas supply.
These units MUST be installed by a certified installer, which I am. I have installed quite a few of these and so far with a 100% success rate and NO failures, ALL happy customers.
