Braided Oil cooler lines FS
bullet87
I have a stock location oil cooler that connects with you stock or aftermarket radiator. This is a perfect fit to clean up you stock oil cooler lines. The lines are actually a little bigger that the stock lines , but shorter in length for better flow. With the two swivel and high pressure ends, this makes for a easy install. I will need a stock oil cooler, minus the lines in return. Best offer :cool:
Lines are made shorter than the unit in the picture. So there is not as much line as the one in the picture. And the lines are -10 with swivel steel fittings. $90 plus ship.;)
