Braided oil feed line,oil press.gage,GM MAF sensor for now.
Do you know how to do Aeroquip hose ends? They are fairly easy. If you are interested, I have an old line that had a leak 1.5" from the end of the fitting from the hose rubbing on the turbo cover. The line could be cut and replumbed if it's long enough, if not it would need a new hose. It's probably 10 years old so it may need a new hose anyway.
If you are interested contact me direct at mbalascak@sikorsky.com
and I'll send it to you really cheap.
I have a mechanical oil pressure gauge with a 3 foot line if you're still looking, it is the size just bigger than the a-piller gauges.
