not the dual piston calipers.
you need to S10 spindles for that- which looks like a good idea until you start pricing replacement parts for it. the wheel bearing assembly is right around $300 each- compared to about $15 for all the bearings and seals for both sides of the stock stuff on your car now.
i think SSBC sells a multi piston caliper that bolts to your stock spindle- but they are mucho $$$- and they also sell single piston calipers with much bigger bores in aluminum and cast iron, as well.
but for the same money as any of these options, you could look at adapting Corvette PBR calipers to your stock spindles with 1LE 12" Camaro rotors. it isn't a bolt on deal, but if one goes bad, a replacement is easy to find anywhere.
