I recently had my motor rebuilt in my 1987 GN (.020" off cylinders, .010" off heads, upgraded cam, new parts...). I took my car out for a test drive. The brakes worked for about 1/2 mile and then the pedal got really stiff and I had no brakes! Luckily I was only a short distance from home. Prior to the rebuild, the brakes worked fine.
What should I investigate (powermaster? pressure switch...) as the cause? Do I need to add a booster or change out some other parts? Any way to diagnose?
Any help provided would be great! I am anxious to drive the car!
