Brake light
HOTSIX
Ran outta hand cleaner
I did the vacuum brake conversion and now i'm left with the 2 plugs and wiring harness hanging outta the firewall where they used to plug into the Powermaster system I removed.
Problem is...the "BRAKE" idiot light is on and will not go out. I have bled the system so I dont believe this is the cause - meaning the switch on the combination / porportioning valve.
Would these unplugged wires cause this light to come on ?
If so, how do I make it go out ? Ground out a wire on the harness ?
then wires wont do it.
go back under the dash and make sure you didnt mess up the switch to the emergency brake..:)
only one of the wires off the power master should be attached to any thing and its a power wire.
it should be tied into one of the power wires on the delay relay ..the big one of the 3.
i just cut mine loose at the connection and kept them...y i dont know but it could easily be reatached.
