Brake light
smallv6
Still in Block Learn Mode
Everytime I apply the brakes the Brake light goes on for a moment
The brakes are good and I dont hear any groaning from the powerslug. What could this be?
Check your brake fluid level. Read the instructions on the master cylinder resivoire cover first though. This has happened to me in the past and the level was a little low. Good luck....
I would first check the brake fluid. Follow service manual directions on this as it is slightly different than with vacum brakes. I would then turn key on and listen for the pump. Once the pump stops step on the brake pedal. If the pump starts immediatly then you probably need to replace the accumulator ball. This is an easy fix and about 90 bucks from most TR vendors.
