You'll have to get up under the dash to see if the contact switch has moved out of position. It's gray plastic and if it has moved you should see a bit of disturbance on the plastic threads. Not having brake lights may mean the switch is unplugged or defective. There could also be a ground issue between the fuse box and the rear light harness... lots of options, none of them all that fun to work on!
