BRAKES poping fuses
bobby690_11
Hello Im new to this site but have been on it and getting lots of great info from all the threads.My problem is my brake light came on while I was idleing in the garage.I noticed a few time before some wierd noise coming from the dash area that I thought was a bad speaker.Well I got reading on this site and found out theres a motor on the brakes and its making a racket and it blew the fuse.I put in a new fuse and the noise is back.I wont try it again untill I know how to fix it.Any suggestions will really help.Thanx:confused:
Powermaster motor making the noise and most likely blowing the fuse. You're looking at replacing the brake unit with another powermaster or converting to a vacuum brake system. Try the search feature on this site, lots of info about these brakes...
Good Luck,
-Jimmy
kirban 2 cents worth
It could also be something simple like the brake switch...had it happen to me several years ago...try another brake switch you may get lucky...
kirbanperformance.com
denniskirban@yahoo.com
This is assuming motor is not making noise and you see no fluid anywhere.
