brass fitting for turbo oil return
Velon
Anybody know if I can go to a local Home Depot or somewhere and get the brass fitting that screws into the block on one side and stock turbo oil return line on other side. Had aftermarket line and kept leaking and wrong sizes so I'm going back to factory, but I guess I accidentally threw the adapter fitting away when I threw my old return line away.thanks
HD has a nice brass fitting section...I found a oil feed line to turbo elbow fitting there for a replacement
Unfortunately, the oil return line brass adapter that goes into the block/valley pan area on 86/87 engines has long since been discontinued. I do believe Gbodyparts might have used ones tho.
HTH
Patrick
