Breather Block Off
V666
There is a leak in my turbo hose between the turbo housing and intercooler. It is shooting oil out onto my fan. I plan to replace the hoses shortly. Is there a way to block off the breather without hurting anything?
Remove that silly stock breather set up. All it does is suck oil into the intercooler when you're under boost. Replace it with a paper filter thingy style valve cover breather and use a rubber cap on the port on the turbo housing.
