Oil in exhaust and out breather (passenger side) under boost
pjnutt
As stated in description. At idle I have oil (smoke coming out of my exhaust) and dripping from tailpipes and around turbo. I have pulled and checked PCV valve and I can blow through it and get 99% of my breath to stop, obviously wide open in the other direction. Turbo is about 7 years old but being in Michigan probably only has 5000 miles.
What should I be checking outside of the PCV valve? What's odd is that there seems to be condensation at the tail pipes (more extreme) and from the turbo area. It puddled on my driveway but didn't leave and stains like oil would.
Any input would be appreciated.
and around turbo.
Pull the downpipe and the intake pipe.
Most likely the exh side will have oil in it.
Check end and radial shaft for excess play.
Figure that the O2 sensor is fried with all the oil that's blown past it.
