Sorry sometimes I'm a dumbass, so your saying that my trans is from a monte?
NOT a dumass. Just try to continue w/ 1 thread, when discussing something.
Lots of info on Google:
These codes can be found on the passenger side of the transmission near the output shaft. Sometimes they are hard to read due to the catalytic convertor getting in the way. The valve body itself will have the first two letters painted on it. Be careful because the paint comes off easily. The special valve bodies usually have a purple strip on them also.
TH-200-R4 ID's:
ID Year(s) Application
KZF ** Olds 442/Hurst
CZF ** Monte SS
BRF ** GN/T-Type/Turbo Regals
OZ ** Hurst Olds
OM Olds 350 Diesels
OG Olds 307
BY V-6 252 Cars
AA and AP Cadillac's
More info from the g body guys..
The best 200 4R trans have an 'F' as the 3rd digit of the letter code. ie. CZF, above. These are 1986 and later. Some of the costly items usually installed by a specialty trans builder are already in these trans.
The G body 200 4R trans have the following codes:
Chevy, CR; Monte SS, CQ, CZ.
Buicks, BY; turbo-T and GN/GNX, BQ, BR.
Pontiac, CC, CY, CH; 2+2, CA.
Olds, KB, KJ, KT; Hurst, OZ, KZ.
The question about a Caddy with a 200 4R trans are coded AA, AP.
The 'F' upgrade trans have different hydraulic control components and the rotating group is about the same.
