FINALLY. The header is off. Only been a four day evolution. Only been working on it a couple of hours a day in the evening. Whe it is 114 and the car is not inside you work in the evening. Turns out the #2 is cracked on both sides of the weld and the crack almost runs from the weld to about an inch down the pipe. Glad I didn't have this guy try to weld it while it was on the car. Shame of it all is that you have to basically pull the whole front end off the car to get to this thing. On a postive note if allows me the opportunity to clean behind all that stuff too. The A/C let go while the previous owner had it and it made a huge mess that was never cleaned up.
Time to change the plugs, wires and distributor while it is all apart. Cannot believe more has to come off to work on the distributor. As a friend said, they were dark years for GM. With respect to all the SMOG.
