Drewster
Wish I Had A Clone. AKA Andrew Youlio
- May 31, 2001
its been pretty hot in my area. (105ºF) I notice that my SMC kit was not spraying the way that it should.
When i looked in the storage tank i saw bubbles coming out of the pump pick up tube.
I think the methanol is vaporizing in the suction tube causing the pump to loose prime.
i just thermo-wrapped the down pipe and meth pump pick up tube. it still makes bubbles but not as much.
My AC has been out for a really long time. I notice the AC accumulator is blazing hot. the meth pump is strapped to the accumulator with some foam insulation between.
I thought the nozzle check valve was bad but no bubbles until the engine water temp gets to around +175ºF
Any idea how to stop the bubbles? Add water?
is my AC unit burning up causing excessive heat or does the accumulator normally get really hot when not running?
