Feb 8, 2006 #1 B buickbob New Member Joined Feb 6, 2006 Messages 36 I need to know to find out what the production codes mean and also how to decode the vin.Can any one help me car fax, I tried several times and it wouldn't let me past the vin. Thanks Bob
Feb 9, 2006 #2 M mikec1969 Member Joined Dec 11, 2005 Messages 149 The best site I've found for RPO codes is:http://www.gnttype.org/numbers/rpo.html Good luck.
Feb 9, 2006 #3 B buickbob New Member Joined Feb 6, 2006 Messages 36 mikec1969 said: The best site I've found for RPO codes is:http://www.gnttype.org/numbers/rpo.html Good luck. Click to expand... Thanks for the info. What I'm trying to find is the axel code . They only show three gu4,gu5,gu8.Would you know any more?
Feb 9, 2006 #4 M mikec1969 Member Joined Dec 11, 2005 Messages 149 GM8= 2.56 axle ratio. GU6= 3.42 axle ratio. G80= Limited-slip differential. I believe most T/R's came with the GU6 3.42. Mike C.
Feb 10, 2006 #5 B buickbob New Member Joined Feb 6, 2006 Messages 36 buickbob said: Thanks for the info. What I'm trying to find is the axel code . They only show three gu4,gu5,gu8.Would you know any more? Click to expand... Thanks Mike
