Sump pickups and oil pans
jrsnell
I have a 1978 231 long block freshly rebuilt and I am trying to sort the oil pan and pickup. Currently, I have a core with a center sump oil pan and the proper pickup for that setup.
It turns out the old oil pan has had enough pitting in the pan to put a pinhole in the pan. There's other pitting, so I intended to purchase another oil pan... however, a center sump oil pan seems to be fairly hard to track down.
Can anyone offer some input as to what's involved in converting this to a rear sump oil pan... I assume a different pickup is needed and if it's possible to source these somewhere. I'm having a helluva time finding an oil pan and the information that I can find about 1st design and 2nd design pans and pickups is confusing, to say the least.
I'm putting this in a willys pickup, so I have no space concerns that would dictate needing any particular sump location, so if I have to replace the pan and the pickup, I'd just as soon go with a rear sump.
Anyone have any ideas, input and/or sources?
Thanks a ton, Jeff
Considering these guys offer the factory pan upgrade they could probably tell you more.
Every place I've looked it's either discontinued or out of stock at the moment. I did find a new one still in the box on my local FB marketplace. I am looking into that today.
Any idea how to spec or find a sump with the rear pickup without buying it, trying it and possibly returning it? A Melling part number or similar? At the moment, even though I found a possible pan, I have no idea what to look for when I'm looking.
Following up... I did buy the pan I found on FB Marketplace and it used what they call the "First Design" pickup, which is not the one I had on hand. So, I found a pickup for a 4.25" deep pan (which is the new one I bought) and it should be here tomorrow and I will test fit it then.
