dngrous_dime
- Feb 10, 2009
Okay, I got a decent deal on a complete 4.1L engine. It's going into a 96 S-10, which I'm fairly certain has never been done before. I'm not sure which year it is, exactly.
So, what I'm doing, is taking the fuel injection setup from an 85 Century. Clutch is going to be hob-jobbed from several sources, my mechanic is in charge of that. I got the bellhousing from a 79 Monza with a 3.8L, as well as the flywheel.
Trans will be a T5 from a 93-95 V6 F-body. I know I'll need to run bucket seats to work with that trans, which is fine. I love having the shifter tucked up close to my thigh, anyway.
So, the question I have, is how much trouble will I have, trying to get the Century accessories to work with my 4.1L? Mainly the crank pulley, since I can't get a clear answer on how it's mounted. The reason I want to use the Century stuff, is so the water pump outlet will be on the driver's side, rather than the passenger.
Plus, since it's tucked closer to the block, it gives me more leeway for engine positioning.
I'll be running an E-fan (probably from a Northstar), and a 4.3L radiator. (keeps it looking factory)
Total budget for the swap is $2K, and I've gotten good deals on everything so far.
