- Jun 6, 2001
TCI Streetfighter 2004R transmission out of my 86 GN. I have modified this transmission with the following:
Installed my original GN BRF valvebody.
Installed original GN 1-2 accumulator.
Art Carr shift kit
Modified for NL converter (but can easily be reversed for Lock-up converter)
Deep Hughes transmission pan with magnetic drain plug.
Governor modified by Bruce Toelle of Performance Transmissions
This transmission has 15K miles and bangs solid on every gear change. It has ZERO problems, it works Perfectly. If you have over 550hp to the rear tires look elsewhere, this is great for a low 11sec. car which is what my car was. I am changing to a high powered stage 2 and I will not put this behind it. It has worked fantastically for me, ready to drop in and run, needs nothing. Comes with original TCI manual/instructions as I purchased it new. Will post pics tomorrow.
Prefer local pickup but If you want it shipped, you will need to arrange it, I can strap it down to a pallet to prepare for a freight pickup.
975.00 SOLD!
Mike
Art Carr shift kit
975.00 SOLD!
Mike
