all these parts are leftovers from upgrading projects
all parts plus shipping unless otherwise stated and 3% extra for paypal
paypal only unless you come in person to pick parts up
48 us states only shipping no canada no islands
paypal is asloan5@bellsouth.net
on large items ie tires, sway bar,drivesshaft I can have these available for pick up in lake city, tampa or crestview fl and monroe ga at no additional charge.
try to use pm's if your interested so the thread does not get all clogged up please
all pics
Image hosting, free photo sharing & video sharing at Photobucket
1 stock injector harness 1 injector plug is broken but works fine and is replaceable if needed 35 shipped
2 various bends all 3" make offer on one some or all the funny looking one on the end is off of an 04 powerstroke , The large curved one is chrome all others are not. I originally bought these as an install kit for a powerstroke IC 80 shipped for all in pic
3 auto meter 2 1/16 electric fuel pressure gauge (no sending unit) make offer
4 orig 8.5 pinion flange make offer
5 86-87 oil cooler adapter with lines and like new o-ring from gm 60 shipped
6 remote oil filter adapter this adapter will screw on to stock gn with a biggie adapter so you can run a remote filter and the 2 holes in top are 1/2 npt 15.00 shipped
7 pioneer radio with cd player with g-body brackets and conversion harness so you dont have to cut your factory radio harness 85 shipped
8 rjc biggie adapter 30 shipped
9 dvd video how to install and tune and xfi system watched it one in like new condition 25 shipped
10 battery hold down 10.00 shipped
11 radiator overflow jug 15.00 shipped
12 86-87 cruise control assy. complete with bracket and cable ..vacum diaphram is bad but it's all there 20.00 shipped
13 86-87 stock aircleaner box bracket 10 shipped
14 86-87 stock fan assy 85 shipped the tab on the plug that holds it to the the shroud is bad an being held on by a zip tie very useable and when installed you will never know
15 front solid swaybar 1 1/4 thick with brackets bushings and endlinks 35 plus shipping (heavy)
16 1/2" aluminum fuel line left overs from project 18 shipped
17 short negative heavy duty battery cable. I used this when I relocated battery to trunk. 14 shipped
18 radiator very clean inside no leaks appears to be original 100.00 plus shipping
19 factory driveshaft for gn with 200r4 and 8.5" rear end 100.00 plus shipping.
20 set of 4 225-60-15 fuzion tires 80-90 % tread left very nice shape 125.00 picked up
21 used oem gm 20 bolt timing cover has wear at the usual cam thrust will need to be machined down some an use a thrust button 45 shipped
22 brand new gm coil pack (coil and module) never bolted together 240.00 shipped still in gm boxes (no pics of this)
all pics
