Burned Out Lights
rickringle01
Can anyone tell me how to replace the burned out turn signal indicator bulb in my 87 T dash. Is there a place to find a diagram of the dash?
Easy, pull out the dash surround trim piece and you'll see the fronts of the dash cluster with warning lights, and turn signal indicators can come off seperate. Unbolt the two small bolts (probably 7mm), remove the trim, and covers.
Burned OUt
I got that far, but the light dropped behind the cluster. It was in a green/blue cap and when I twisted it it fell back. Is there a way to remove the bulb without removing the cluster. OR do the bulbs remove through the front or rear of the bracket they are fixed in?
It's not a big deal now that you're this far to take off the padded dash surround. Once you have that off you should be able to look behind the cluster and fish your wire out.
