Bushing removal
Morkai
Morkai the Red
Well, I'm having better lucking getting the other bushings out. My question is how the #%#* do you get the bushing out of the forward clutch housing shaft? Looks like no way to get behind it to get it out, unless you use a tap or something. I might just take that one to a shop and see if I can get them to do it.
Also, the bushing in the O/D planet seems hard to get at. Any pointers?
Rear Planet
Got the rear planetary bushing replaced, that wasn't too bad.
Slowly but surely...
Well, I have every bushing changed but the forward drum shaft bushing, the O/D planetary (the two I may have to take to a shop to get out,) and the pump, L/R center, and stator bushings...the later two of which I'm waiting on new parts.
Nobody can tell me how the shop gets the forward clutch shaft bushing out?? About the only idea I can think of is to thread it with a tap and pull it that way. Unless there's some special tool that goes in and grabs it to pull it out...
(My shop press has really earned it's money here) :D
