sugarandopium
where were the spiders
- Oct 11, 2008
Will probably be moving to SoCal within a year.
My other vehicles are either stock or a few bolts away from passing a sniff test.
The buick on the otherhand....
has no cat, open air filter coming off the MAF pipe, 60# injectors, downpipe, ta49, alky...
Pretty much all the usual basic mods on these cars, disregard signature... havent been updating it..
The engine is still stock/unopened though.
How much trouble am I going to have getting this car registered/inspected?
I read somewhere a while ago that the car has to go through a serious inspection
with both visual and sniff test BS before they will even register a car, is this true?
If I put a cat, stock air box, and tt emissions chip, will that suffice?
Will the aftermarket downpipe cause problems with the visual?
How often do you have to go through inspection there?
I figure this is prob a big N-O, but are there any ways to get around it..
such as some states that have collector, classic, antique, limited use type registrations that do not require inspections?
What are you guys with the lightly modded TR's doing to pass?
Thanks in advance for any info/advice!!!
