Sal Lubrano
- Apr 26, 2002
Hello, I am faced with an expensive repair and I would like your opinions if this would work and what would you do. My 1999 Jeeps grand has heated seat except the passenger side has gone bad. I have traced it down to a bad thermistor. The good seat in the morning at 65 degrees reads 9.13 ohms across the thermistor but the bad reads 138 ohms. I have checked the resistance across the heating element as well and they were good in the bottom pad and top. I called jeep and her eis the funny part. The thermistor and heating elements are inside the padding along with the leather. The price is $600. Yeah that is what I said! I am now on a mission to replace the thermistor. After some research I have found out this.
The temperature sensor is a Negative Temperature
Coefficient (NTC) thermistor. One temperature
sensor is used for each seat, and it is located on
the seat cushion heating element for all models.
The seat heating elements are sewn into the seat
cushion cover trim and seat back cover trim units.
I am taking for granted it is a 10 ohm thermistor. Due to the fact a 10 ohm will be 10 ohms at 75 degrees and I read the good one at 65 degrees and I had 9.13 ohms. Took the seat cushion apart and this is what I found if you look at the picture. The thermistor is connected to the black wires. It is a long piece of wire which goes up and down the bottom cushion. I want to solder in a new one but I am on a hunt for a suitable replacement. I have found this company. I was thinking about using the thin film one they have but it will not weave through the seat. I have no proble cutting the foam more and running a new wire and then using some glue to hold the foam and wire but where would I find this thermistor type or do you think the film type would work? Any input would be a great help. Thank you.
ECC Division | Selco Products
