Calling all SyTy, alcohol tuning gurus.
TiClone
I finally finished installing Razor's PAC. Took the Sy out for a drive around the corner with the DM hooked up. Question I have, what fields on the DM are most relevant to performance increasing? Is the KR and MAT temps the main area to watch when tuning with alcohol?
KR.. its rule one.. no KR..everything else will always fall into line.. if it doesnt, your not hurting the motor.
Drop your timing, add boost in the chip, start trimming down the fueling to make up for the alky being sprayed. Typically you should be able to hit 20 PSI without almost any tuning. Just watch your KR.. take it from there. Your intake air temps will come down with alky.. but its a who cares if the motor doesnt KR.
Start on getting the tach flutter issue handled.. then move from there. Call me tommorrow ... i'll get you the cap and some wiring for you to play with.. OK?
Julio
727-526-9724
Julio, thanks for the offer. I haven't been online all weekend, so I'm just replying to your post. What day/time is good to call?
Thanks again, Ticlone!
