You can solder resistors onto the calpak to change it. I don't recall the specifics but there are some pins that control the slope of the PW vs the CTS, along with a knee in the slope. Like going from a choke mode with extra fuel to a regular mode.
Pin 16 is +5 volts. With pins 4 & 7 being ground. Can place the resistors between a calibration pin and then either 16 or 4/7 to change it.
Best to have an ECM bench to do this. That way the injector PW can be observed while running the ECM.
Because when you are running injectors that are twice or more the stock flow rate. If the ECM goes into limp mode the engine will immediately flood and foul the plugs. It takes a whole bunch more work to get the engine running vs. walking home.
Only a spare ECM/chip and six new plugs will get it going again. Plus the tools to change the plugs on the side of the road.
And limp mode is only a loose PROM chip or flaky ECM away.
