cam bearings stage 1
norbs
Classic fast, XFI, SPortsman & MS3 programming
I have a set of Cam bearings here from TA performance, however, i thought the #1 bearing is different, these look all the same they have oil holes at 3 oclock and 7 oclock, and groove od the back. Is the number #1 bearing supposed to be wider?
They use all #1 position bearings in there sets & groove the back so you can clock them in any position & still get full oil flow.
You should run the wider #1 bearing in all the saddles. This is probably what T.A. has sent you.
Very slow process, have to send the crank for balancing, since no one in Canada knows how to balance it!
