if it fell out it can get real ugly...
you should be able to see it thru the cam sensor hole if you pull it out .
when i slide the cover on i make sure the cover springs back off the block before bolting it up also if it dont fit tight in the end of the cam i stretch it open some with some pliers to make it fit tight.
