Key stuck in ignition
Dhos1
Self-tuning wanna-be
I just changed the driver side window motor and wanted to do a quick check to ensure it works before button it back up and now the key will not come out. I do have the transmission out to be redone. And ideas. I’m sure it has to do with a linkage of some sort
If you have a console shift car, try rotating the plastic cover near the base of the cluster.
Sometimes is gets just a touch out of whack & it won’t go fully into Park.
Tried that, will continue tomorrow. I still think it may have something to do with the disconnected linkage, but who knows. I’m tired of fucking with it for now
I understand.
That column piece is directly connected to the linkage(again if ya have column shift).
Can also try moving the wheel back & forth. Been known to happen as well.
What others have said is spot on... moreso as you said you have the trans out, the weight of the linkage will rotate the column to the right.
Rotate it back to the left and it "should" allow you to rotate the key to the off position then remove it.
even a floor shift car uses wheel lock that can keep the key not going to lock position
raise the rod that has the slip nut that goes to the shifter arm
Where is this rod / slip nut
the rod should just be hanging on drivers side, as said sometime you can rotate the sleeve on the steering column and release the key
But it will be easier to have your wife lay on her back under the car and lift the rod will you turn the key to lock position
