Getting ready to install an ductile roller cam from full throttle, and wanted to know what you guys are doing to check the end play on the camshaft. I have heard some saying to shim it until it has no play and then take one of the thin shims out (sounds reasonable) what is the end clearance supposed to be?
While I'm at it, what should the lifter preload supposed to be on the morel lifters?
