cam gear
newhotair
if one of the teeth on the cam gear is broke does the cam need to be replaced are is there something that can be done beside replacing the cam
Unless it's a small chip off a corner that can be deburred it needs to be replaced.
Your wording is a bit misleading, do you mean replace the entire camshaft or just the broken cam gear newhotair?
Post a pic so we know which gear you are referring to
i mean the gear on the cam that drives the cam sensor a teeth was broke on both the cam sensor gear and the gear on the cam that drives the cam sensor do to a bad oil pump that lock up i have a new cam sensor i need to know if something can be done about the cam gear
You can't repair it. If it fails it will leave you stuck and you will have a lot of work to do to fix it.
