if you have the #1 piston at TDC and you stick the cam sensor in the front cover, which way should the gap in the ring be facing and where should the wires on the cap be facing?? anyone know?
The piston should be 25deg AFTER TDC or 1.45"
Drop the sensor in with the mark (on the sensor gear) in the 11 O'Clock position. It will work out from there.
