michael evans
- Feb 27, 2008
Have datalogger (all looks good and no codes). Had a couple issues. After I cut and changed three of the five wire to the ECU (and it did not fix it found one bad wire though), I stepped back and rethought it over.
It sounded like a load problem. So instead of using my meter, I got out my old load light that I made in the Air Force.
Although the "M" terminal on the CCCI plug showed 12 volts with my meter, it would not light up my load tester.
I traced the wire to the fuse box (ECM 10 amp fuse).
How does the fuse get it's power ? I am guessing the ignition switch. The diagram I have doe not show it.
Will not having enough power on this wire damage the module ?
