turbodaniel
clean air 1
- Nov 14, 2007
currently running this cam in my 235 which i know isnt the best choice but i would like to use in another build... so am looking for input on whether it would be worthwhile to use again or go with something else
the specs:
comp cam hyd roller
.555 gross lift
236 duration at .050
.347 lobe lift
113.0 lobe separation
my build is a t/a alum block 274 ci
fully ported gn1 heads
champion intake
95 lb injectors
71 billet wheel turbo
the specs:
comp cam hyd roller
.555 gross lift
.347 lobe lift
champion intake
95 lb injectors
