Originally posted by turbobooster
hmmm interestin info that would be nice to have my car rev to 6000 so when choosing the cam the higher the number like 206 or the 210 the more power its better for? i mean im pretty much stock right now and interested i putti in a cam and do have big plans for it later down the road would like to 12s anywhere in that range but i want to drop in a cam that i can have now and stillbe good for the day i reach that goal dont wana have to change cam alot
The bigger the cam the higher you're moving the power band up, be careful with this you'll need the turbo, exhaust and stall mods to make the most effective use of this move. There are half a dozen or less cam choices that are commonly used, do your research.
Personally, I'm going with the 204/214 for a few reasons, but I'm not trying to move you towards a particular cam. These are some of the things I looked at, maybe they'll help towards a choice. Is it right? Time will tell. The best advice I can give is get a cam for where YOUR car makes power.
1)Cost-I'm not the richest person in the world, and the 204/214s are quite inexpensive and avalible from lots of sources.
2)Documented success with it-The 204/214 has had some impressive times behind it, but this can be said of most any of the cams used and isn't saying much since 10s have been run on the stocker.
3)the extra duration on the exhaust-Turbo motors don't "sweep" the exhaust, you've gotta pump it out and hopefully in theory the extra duration will help spool some.
4)the RPM band-Summit's info on the 204/214 lists it as idle-5500 revs, and most people say it pulls to 6 grand. This power band is more desireable to me then the listed 1200-5500 on the comp 206/206, as hopefully the extra bit of low end will hlep with getting the turbo in motion.
Something that I will point out about this is look at the HP/torque splits of dyno results, then look at the cam installed. The ones with a stocker cam are usually near %25 higher torque then HP, while the cammed ones are a fairly even HP/TQ split.
IMHO a cam is a "while you're in there" addition to a motor, not something that should be done for the sake of doing it.
