Cams Specs 210/205 GSCA
Thanks for the site.... We are actually needing to know something we can measure with a micrometer. Lunati website is all in degrees.
210°
205°
part number 32508
.456" INT
.440" EXH
sarah, have shannon check to see if the part number is the same one stamped on the cam shaft--
then get jesse next door to put the micrometer on it and see if the cam comes close to the
.456 on the intake
and .440 on the exhaust
hth
Thanks for the info Brian.... But we have every number except for that number , LOL. All the numbers are three #'s or 3 letters. Shannon is going to go ahead and check the measurements though that you just posted. Thanks again....
