Turbo1dr
9 Sec Wanna-Be
- May 25, 2001
I've been a busy little bee this year with some custom parts for my Malibu. I cut a front wheel drive lower timing cover in half and welded it to the upper part of a rear wheel drive cover. I done this to get rid of all the wear and stress a HV oil pump puts on the timing components, cam sensor gear and the thrust surface of the block. This also gets rid of some friction. However, by doing this I've also created another problem...maybe. I was cranking the engine on the engine stand with just the starter and noticed the camshaft was walking forward!
This was with the heads installed and the valves adjusted. I loosened all the rockers while looking at the cam and the cam thrust button pushed it back into place. The cam is a ATR Roller 214-210 cam and has about 25,000 miles on it. Obviously, it's lasted this long so I'm thinking I should just put an adjustable cam thrust button on it and let it ride. I can't see how the timing cover modification caused this?
What are your opinions on this?
One other thing about it walking...the thought of the lifter bores not being perfectly in aligned could also cause this.
It's a good thing I was able to catch this before I put it in the car....whew!
Timing cover installed Picture.
