I was somewhat of a guru of intake manifolds for the 99-01 mustang cobras. I was the first (that we all knew of on all the mustang message boards), to use my own car as a test bed and did tons of R&D, developing a new intake design, that ended up beating everyone out there...anyway, those intake gaskets, I was able to use over and over and over and over. Must have pulled my own intake 30 times, and never bought a new set. But those gaskets are a serious kick ass design. I havent seen an intake gasket for TR's that I would use again and again. The cobra ones were made of some sort of thick black laminate with a strong silicone bead around all the ports..on both sides. The all metal ones for the TR's are garbage. The all metal one that was on my engine hadnt been sealing worth a crap, and the gaps from the mismatched angles caused the engine to suck half the RTV in the ports. Old school engine blocks tend to have cylinder decks that are crooked up to .030" (which makes square decking a good idea with any blueprinting job), and this causes the bottom of the intake ports to seal differently than the tops. The Fel-pro's would probably allow you to get away with it a few times, but I wouldnt feel good about it.
