DougsfastZ
4.1
- Jan 30, 2004
So a few months ago a had the car dialed in at 23 lbs of boost on the stock turbo and running good. I had a boost fluctuation issue and figured it was the stock wastegate actuator since I heard they are only good for about 20lbs. I ordered a brand new HD actuator with an adjustable rod. I'm (and have been) running a RJC boost controller. Since I installed the HD actuator I haven't been able to build more then 18 lbs of boost. It doesn't matter how I adjust the boost controller I can't get any more. Plus the only way to build that amount is if I have the rod threaded all the way in. If I set the rod in order for me to pull it a 1/4 inch ito get it on the puck, I can only build 8 lbs. I have checked all vacuum lines and intercooler piping and it all checked out. The only thing I can think of the puck isn't sealing, but I'm on a stock turbo with a brand new THDP 3" DP (with a 1.375" puck). One thing though, on one of my test passes yesterday I did build 23 lbs, but was never able too again.
Any ideas?
Doug D
Any ideas?
Doug D
