Can someone point me to where the fuel pump relay is located.
Thanks.
I was thinking its under the dash by the fuse box.
Can I get this item from GM anymore or Autozone?
The high speed relay connector has a green wire with a stripe, where the low speed relay has a solid green wire in it.
The relays themselves are identical. The connectors can fit either way which could confuse High and Low, but the wire stripe tells it all.
