The car stalls when put into gear, when I drive the car and come to a stop the car surges, when I put the car in park from gear, the idle sky rockets to 3,000 rpms or so. I can get it in gear but I have to neutral drop it to do it.
There is no lock up oil behind the lock up valve in park, reverse, neutral or low. BUT , If the valve is stuck in the bore down , yes you could potentially have this problem. The solenoid wouldn't matter tho. It would have to be the valve stuck. I would check the converter. Pull trans out and stick in a known good d-5. See what happens. Or pull pan, pull solenoid and see if the valve is stuck in the bore.
