On my 87 grand national I was running 18 psi of boost, I switched out engines got a ta49 turbo, 60# injectors e85 fuel and turbotweak chip. The chip is set at 25-26 psi of boost, but at first I was only doing 10 psi of boost. I adjusted my wastegate rod all the way and was only getting 20 psi of boost. Took in out driving again and now only 15 psi of boost. Do I need to go with an external wastegate to get to 25 psi or is there a problem with my chip.
