Can't find fuel pump relay...
artrenee10
Older...wiser...and broker...
Using a casper's special but cannot find the fuel pump relay that actually came with the kit..
Part numbers are :VF28-67F24-PO5
Second set of numbers are 12193603
Brand name is Tyco..checked radio shack...autozone, Advance Auto....still coming with the incorrect relay. It is a four prong, and the parts stores keep on giving me 4....
Not good....
Can anyone run these part number and possibly point a brother in the right direction?
Steve Chambers
Do you mean that you are getting a five prong relay? The five prong relay will work. The fifth prong is the current flow when the relay is off. So B+ goes into prong 30 and when turn on will flow to prong 87. But when power is on prong 30 and the relay is off power will flow to prong 87a.
Thanks.....
Ill go back and grab another one...
Thanks again
Steve Chambers
No problem. Just make sure you get a high amp relay. A 30 amp one should work fine.
