I will try to make this short. Had some mods done, Alky kit, 30 lb injectors, Turbotweak chip set up for Alky. I also at the same time put on a HD actuator and found that at WOT the boost would go to 25 lbs. I tried to lower the boost by extending the rod and had the rod so far extended that there was no tension on the pin. Still 24 lbs boost
I then decided to put the factory actuator rod back on and still boosting at 22 under WOT with the rod pretty long. I can extended it several more turns to make it longer, but it shouldnt be boosting that high with the stock actuator at the length I have it at.
I checked my WG selenoid (which is about 1 year old), the 3 hoses and Y connector (which also is about a year old)
Any ideas what else to look for to find out why I cant lower the boost ?
I know it has nothing to do with the mods I mentioned above unless during the installation by my friend, he disconnected or screwed something up ?
