Well, I just finished doing my body mounts in 3 evenings! I will never do that again on a 20 year old car! I had to make a new fitting to be placed in the #6 area because it was all rusted out and the bushing was pushing through the frame. Also, the frame was off alignment so it was a lot of fun trying to get the holes lined up again. One thing though is I'm not sure how tight you are supposed to tighten the bolts. The gnttype instructions say snug but it seem as if you could turn forever and just compress the bushings. I just went until I felt a little give and about a 1/4 turn after that.
Anyway, I went to start changing out the engine mounts. I lowered the car, took the front wheels off and raised it back up. I have no idea how large the cross bolts are (the ones that go from front to the back ofthe car), and there is no way I can access the passenger side from the front. The oil filter, the k-member, the lower control arm, everything is in the way! I have no idea how you guys seem to be able to do all this stuff on jackstands because the passenger side is pretty much impossible for me. I have extensions and universals but it seems a no go.
So, now that I am done complaining how much does a shop charge to have these changed out?
